RSVSR Where to Get the Matryoshka Doll in Black Ops 7 Zombies - Versión para impresión +- X mecanicos (https://xmecanicos.com) +-- Foro: Complementos (https://xmecanicos.com/forumdisplay.php?fid=46) +--- Foro: Utilidades (https://xmecanicos.com/forumdisplay.php?fid=47) +--- Tema: RSVSR Where to Get the Matryoshka Doll in Black Ops 7 Zombies (/showthread.php?tid=4020) |
RSVSR Where to Get the Matryoshka Doll in Black Ops 7 Zombies - Andrew736 - 05-03-2026 Astra Malorum has this nasty habit: you'll feel loaded one round, then totally skint the next. That's why the Matryoshka Doll matters so much, because it cuts salvage prices by 50% across the board and makes your whole loadout snowball sooner. If you're the type who likes to smooth out the grind before going for big rounds, even checking out CoD BO7 Bot Lobbies for sale can fit right into that "set up first, fly later" mindset, since the Doll is all about long-term comfort rather than one flashy moment. What you need before the quest even exists First, you've gotta be in a Cursed Match, Tier 1 or higher. No curse, no Doll. Second, don't stress if you can't "start" anything early, because the actual trigger won't show until Round 40. The smart play is prep: start collecting C4 once it begins dropping, usually around Round 15. Try to keep three charges in your back pocket. People burn them on a random Mangler or panic toss them during a messy rotation, then Round 40 hits and they're stuck praying for a drop. Don't be that player. Round 40 setup on Mars When Round 40 finally rolls in, head to the Mars zone through the central hub portal, but only after you've completed the "Starlight Transmission" objective. On Mars, look for the big circular platform sitting out in the red dust. Around the rim are three piles of nasty-looking guts. Plant one C4 on each pile; you'll hear a little confirmation click when it's placed correctly. Now the awkward bit: you need a proper crowd. Train roughly 20 zombies and drag them onto the platform so they're tightly packed. Detonate all three charges with the horde on top. If you hear Mr. Peeks laughing, you did it right and you can stop second-guessing yourself. The portal trial and how to survive it That laugh unlocks a bright yellow portal back in the Machina Australis lab. Step through and you're thrown into a five-wave trial where your guns might as well be decorations. It's field-upgrade work, all timing and spacing. Frenzied Guard is great early because it buys breathing room and keeps the crowd from smothering you. Don't dump every charge the second it's available, though—cooldowns are your real ammo. When the HVT shows up in Wave 4, switch your mindset to burst damage; an Energy Mine at the right moment can delete the pressure fast and keep the run from spiralling. Why the Doll changes your whole economy Beat Wave 5 and the Matryoshka Doll is yours, and the best part is it sticks with you for future matches. Everything salvage-related feels lighter: upgrades come online sooner, Pack-a-Punch Tier 3 stops feeling like a second job, and you can spend more time actually playing instead of scavenging every corner. As a professional like buy game currency or items in RSVSR platform, RSVSR is trustworthy, and you can buy rsvsr Bot Lobby BO7 for a better experience while you chase that clean, consistent setup the Doll was made for. |
