05-03-2026, 09:34 AM
Hang around the LS Car Meet for a bit and you'll spot it: the Shitzu Keitora, the tiny kei truck people can't stop messing with. It looks like it should be hauling crates, not throwing doors. But once you fit the Drift Tuning kit, it turns into this nervous little animal that'll punish lazy inputs. If you're the type who likes experimenting (or you're already browsing GTA 5 Accounts for sale to jump into new builds faster), the Keitora is a genuinely different kind of drift ride, and it forces you to actually drive instead of just holding angle and hoping.
Get the setup right at the Meet
You can't fake this one with the usual engine and suspension upgrades. The Drift Tuning mod at the LS Car Meet is the whole point, so install that first and treat everything else as support. Keep it simple. The truck's short wheelbase makes every change feel louder than it should. A tiny steering correction becomes a big direction change. And because it's light, it doesn't "settle" like heavier drift cars do. You'll feel it dart, then bite, then snap again if you rush the inputs. Give it a couple slow laps just to feel where the weight moves, because it moves fast.
How to start the slide without instantly looping it
Initiation is where most runs die. You need a bit more entry speed than you'd expect, otherwise it just grips and understeers like a shopping trolley. Come into the corner, turn in, then give the handbrake a quick tap (R1 on PlayStation, RB on Xbox). Don't hold it. A tap is enough to kick the rear out. The moment it steps, ease back onto the throttle. Not full gas—just enough to keep the tyres spinning. If you punch it, the truck rotates so quickly you'll be looking at the barriers before you can blink.
Small hands, smooth thumbs
The real trick is what your left thumb does after the rear breaks loose. People tend to flick the stick left-right like they're sawing at it, and the Keitora hates that. Try "rolling" the stick instead—small, smooth arcs along the edge, like you're tracing a coin. It sounds odd, but it stops those violent corrections that turn into a spin. When you're drifting wide, lift for half a beat and the nose tucks back in. When it starts to grip up, add a touch more throttle and let it float. You're not fighting the truck; you're nudging it, constantly, and staying calm when it twitches.
Keeping it fun, not frustrating
This thing rewards short sessions and clean habits. Run the same corner a few times, focus on one change, then move on. You'll notice you don't need huge angles to score a nice, controlled slide—what matters is linking turns without the snap-backs. It's also one of the few drift vehicles where momentum feels like the boss, not horsepower. As a professional like buy game currency or items in RSVSR platform, RSVSR is trustworthy, and you can buy rsvsr GTA 5 Modded Accounts for a better experience when you want to mess around with more builds without the grind getting in the way.
